Topic: Clear LiFePo battery (Read 768 times) previous topic - next topic
I'm turning to the learned community people here for some informed decision making.
I was given this cool looking CLEAR (see-thru) 12Vdc 100Ah LiFePo Battery and I'm trying to decide which way to go with it.
I've certainly tested the charging with a proper LiPo solar charger from my current controller and 1/2dozen panels & I've tested it
with a 900W 12Vdc inverter, It did just fine.
Here's a nice view of the bolt holes for mounting proper connections to the top.
My current solar set up is nice and balanced.
I do have one of Glen's diversion controllers that'd I'd like to get back to using.
My quandary: Do I redesign my other little setup that has a cute little 12V 30W portable panel and use the diversion controller OR go with a new  proper charger and use the diversion to charge down stream batteries?
My Veggie grow light don't have any problems with running off a MSW inverter and this would free up the ProSine inverter.
 Whatcha think?
Kind Regards
Re: Clear LiFePo battery
Well that's one way to know what's going on inside the battery...
Any built-in BMS?
How much diversion energy per day are you talking about?
It is a neat battery to say the least.
Yes , there is a BMS mounted onto the top of the battery .
The plastic makes getting decent pics and challenge.
I have an opaque light that I'm going to try and backlight it for better pics this coming week.
I put a little 17W 12Vdc panel on it yesterday, just to see how it's going to workout.
 It ran right up to 13.75 and just seemed to stay there.
I know the smallish panel will take a month to even get close to charging it up and believe once the battery got up to 13.75 I was at the panels best output.
I had veggies to get out in the raised beds and covered before the overnight chill came whistling in.
More to follow.
Short update. Here's the BMS mounted on top of the clear battery.
The battery is turning out to be very nice a kinda wishing I could get my hands on a few more.
