Topic: Image uploads (Read 208 times) previous topic - next topic
Image uploads
This system needs work, as much as I would like to add some nice build logs I am not going to manually trim and re code hundreds of images
There are add on's to do this server side
Re: Image uploads
Thanks for the heads up, Xeon. It has been fixed.
Ed
Re: Image uploads
Awesome will test it out.
Re: Image uploads
Ed
Seems to work well enough. Check out the heating section!
Re: Image uploads
Trying to upload the solar tracker build and same issue with images
Re: Image uploads
Hmm.
It looks like it just accepted a 4 MB image, but not a 5.1 MB image.  The limit seems to be set at 5000 kB, now.
Re: Image uploads
That's the hilarious thing these images atm are tiny yet rejected right away
Re: Image uploads
Some of those images are quite large. I’m trying to save space, so I don’t have to triple my server cost for storage.
I increased the attach image size to 7mb and the number of images per post to 7. Hopefully that will be enough.
Ed
Re: Image uploads
Ed
Most forum software has an option to autosize images to the forum needs... I haven't looked at what the forum software package is so no clue if it is an option.
Re: Image uploads
Ed
The image I was trying to upload was 400kb, yet it flags it right away, I'll try and see. This was in the solar tracking sub forum
Re: Image uploads
Worked for a bit then back to rejecting images well under the limit, this side of things deff needs some work!
Re: Image uploads
Hi Xeon,
The issues with posting images have been resolved.
Any other issues, please post them on the new Help FieldlinesForum board after you login.
Thanks,
Ed
Re: Image uploads
Hi Xeon,
Thanks,
Ed
Copy!
